First Antweight
  • First Antweight
    Hi I'm thinking of building a antweight but what do I need?
    What bits do I need and where can i get them from?
    I'm going to buid a basic rambot with a lifter.
    Re: First Antweight
    Hi Ben
    tecnobots do robot servos wich if you bolt lego wheels on them you have drive.
    http://www.technobotsonline.com/radio-c ... ervos.html
    (3rd down)
    you could just use normal servos for the lifter
    http://www.technobotsonline.com/radio-c ... ndard.html
    (one of those should do it)
      Re: First Antweight
      Hi Ben,
      The Technobots servos might be a bit heavy for an Antweight as they are over 60g each, I recommend you take a look at the RobotWars101 forum at http://www.robotwars101.org/phpBB
      Its more Antweight orientated and there is an FAQ section which will answer some of your questions and show you popular places to buy parts from
      Good luck!
        Re: First Antweight
        what kind of thickness aliminum should i use for the armour
          Re: First Antweight
          'What thinkness of aluminium should I use as armour?'
          Answer: Don't. Aluminium is really not great ant armour, 1mm can be used but against a spinner would get fairly easily chewed up, and by the time you've thicked it up enough to withstand the attacks, you'd have been better off with 0.5mm Titanium or 2-4mm HDPE
            Aluminium
            I am using aluminium as my armour and i would disagree
            my ant weight armour is pretty tough and it is relatively cheap.
            However I read somewhere that it can be a max of 1mm thick
            because its metal armour but you know that might be dogey info.
              Re: First Antweight
              The rules changed last year to abolish that rule about armour thickness, so you can have as thick as you like. Has your ant been in with spinners with 1mm Ali armour ?
                Re: First Antweight
                mine has not pretty
                  Re: First Antweight
                  I have...I find that the hardened aluminium I use is quite resistant to surface damage, but it bends easily if the spinner can grab something sticking out or an edge. (so use countersunk bolts )
                  Plastic tends to be a lot better though as it's 'springier' and can absorb more of the energy of the impact by flexing.
                    aluminium
                    It has not fought a spinner robot but i have
                    made a prototype test spining disc and did tests that way
                    also hitting it with a mallet does very little however i don't know
                    where you are coming from if youre using titanium or somthing smilar
                    that will be better of course, seeing as I am relativly new I think if someone
                    else is sure take there advice.
                      Re: First Antweight
                      I've used 1mm aluminium on an ant before, first time it came up against a spinner (Variant, with a big Titanium blade) it got ripped to shreds. 0.5mm Ti holds up considerably better
                        Re: First Antweight
                        Since I have only run tests with a steel 5cm blade
                        does it fair worse in combat with moblie machines
                        or is it how you bond them that cause the weakness
                          Re: First Antweight
                          I would say so, because there are forces acting both ways. In my experience with Variant, the material stayed on the robot and the blade went right through it.
