Lego Chassises
  • Lego Chassises
    For starters, you could make a ant with a lego sheet as a chassis. It's quite a good starter, like I am making the Daleker with a lego chassis.
    Re: Lego Chassises
    Actually I've changed my mind :wink: ; I could probably use the old aluminium chassis instead, but maybe you could stick lego pieces to each other with superglue then put them togther to make a big enough chassis for a Sabretooth Speed Controller :wink: .
