The blurb from SMC says weighs only 10.9g with case and crystal. 2/3 size crystals can be used to minimise weight. 4 channel - Current drain 11mA - Dimensions 21.8 x 31.7 x 13.5mm - Weight 10.9g (with case & xtal) 7.5g (without case & xtal)
Does anyone use one and knows the weight with standard size xtal? Also is it dual conversion?
Whats its performance re. likelihood of interference?
