Build Log | Caractacus - Any Tips?
  • willcaddy
    replied
    Originally posted by RogueTwoRobots View Post
    I made an axe mechanism for my robot Onyx a good few years ago.
    Two things, 1: That video is absolutely brilliant! Made me lol! xD and 2: Thank you so much! That is really helpful
    I'm actually just in the middle of printing out the templates for cutting the main part of the robot out of wood so i can test sizes etc so this is perfect timing
    Will keep you posted how i get on!
    Thanks again
    EDIT: Forgot to ask a couple of things lol. Firstly, when you say the boss of the large sprocket, where do you mean exactly? Not really sure what boss means lol. Secondly, is the tether there in case the fixings fail so it doesn't fly off mid swing?
    Thanks again
    Last edited by willcaddy; 4 April 2018, 14:45. Reason: Forgot to ask a few things lol
    Leave a comment:
  • RogueTwoRobots
    replied
    I made an axe mechanism for my robot Onyx a good few years ago. Started off with a drill motor powering it before switching to a scooter motor as the drill motor gearbox was too fragile. Here's a look at the transmission with the drill motor fitted:
    It's a 5:1 ratio using 8mm 05B chain from Technobots. Think it's a 40T sprocket on the axe and a 8T one on the motor. Just drilled two holes in the axe arm and large sprockect to bolt them together, then drilled a central hole for the shaft, which was 12mm silver steel. It's a live shaft so I used grub screws tapped into the boss of the large sprocket to pin it to the shaft, and then there were 12mm needle roller bearings in either bulkhead (second bulkhead removed for visibility). Made for a very smooth mechanism.
    I then switched to the scooter motor:
    It was a bit ungainly sticking out the back but it was a huge improvement. That just bolted to the baseplate with M6 bolts and again used an 8T sprocket. The only difference was that I welded the sprocket onto the shaft and got rid of the idler sprocket from the first picture as I managed to improve the chain tension. The axe arm was a section of hollow steel bar so I ran a steel cable from the axe head down to the shaft, round and back up to act as the tether, as specified by the rules.
    And the mechanism in action:
    https://www.youtube.com/watch?v=60-9-927nPw
    Leave a comment:
  • willcaddy
    replied
    Originally posted by Ocracoke View Post
    So it is a scooter motor with a cog that drives a chain connected to another cog connected on a shaft to the axe arm (I am sure Hatchet uses something like this, as does BattleAxe and Blacksmith I seem to recall). Fairly simple and quite effective - I'd go and check their respective build diaries to see the mechanism in action.
    Awesome, Thank you very much! I shall go and have a look now
    Leave a comment:
  • Ocracoke
    replied
    Leave a comment:
  • willcaddy
    replied
    Originally posted by Maxamuslead View Post
    for the axe mech i suggest going for the simple scooter motor chain reduction as it works will
    Thank you very much! Would you be able to elaborate a bit because this is a very new thing for me!
    Leave a comment:
  • Maxamuslead
    replied
    Leave a comment:
  • willcaddy
    replied
    Originally posted by Outlaw View Post
    Hey Will
    Best source that I found, and a bunch of other people have lead me to, is directplastics, which does a bunch of HDPE in various thicknesses and sizes, depending on how big you want the sheet to be.
    As for the axe mechanism, I wish I could help but I'm doing my own trial and error testing with my own axe mechanism, haha.
    Best of luck to you!
    Thank you very much for the reply! I hope your axe testing goes well!
    Leave a comment:
  • Outlaw
    replied
    Hey Will
    Leave a comment:
  • willcaddy
    replied
    UPDATE: Its alive! Plus 3D Printing Stuff xD
    Hello everyone!
    Again apologies for the massive gap in posts! I ran out of money again lol I have a new job now so im getting back into building and 3D Printing parts xD Here is the latest few video updates! It actually works now and i have created some 3D Printed parts to mount different parts of the robot. I plan to make these out of Polymaker PC Max when i get a enclosure built
    https://youtu.be/ezHUsyQd9_w
    https://youtu.be/fst5TBajKHk
    https://youtu.be/LVHLuZKOexk
    Let me know what you guys think!
    If anyone has any tips on building the chassis and armour out of HDPE and the best sources then please let me know!
    Also if ya'll can poke Sam from Team Hatchet and direct him to this thread that would be much appreciated lol I need all the help i can get with the axe mechanism!
    As always thanks for all your help! I hope i can be ready for one of the live events soon!
    Leave a comment:
  • willcaddy
    replied
    Originally posted by Giles View Post
    I like the build progress videos, wish more people did those. Keep going!
    Thank you! Means a lot that you enjoy them
    Leave a comment:
  • Giles
    replied
    Leave a comment:
  • willcaddy
    replied
    Im on a roll now xD I have managed to attach the wheels to the motors, draw up some sketches in Google SketchUp for what i want it to look like, hack a PC power supply to power the Turnigy Accucell 6 LiPo charger i have got and mounted the motors to a chopping board for a test bench! Just one more video to go and it will be up and running as far as the electronics xD
    Here are the videos
    https://youtu.be/ARI8lT62TXE
    https://youtu.be/CVemeKzKmGw
    https://youtu.be/FQTJtObznQM
    https://youtu.be/p0ur9bYeL0g
    Leave a comment:
  • willcaddy
    replied
    SketchUp Models Available
    Hey everyone!
    I finally managed to get my speed controllers so I have started to sketch all of the parts I am going to use in Google SketchUp. I don't know how many of you guys will find it useful but as I'm making them I'm uploading them to the 3D Warehouse. I have made a collection and will be adding to it over the next few weeks I hope!
    Here is the link to the collection: https://goo.gl/n62Z8m
    And here is my first every model: https://goo.gl/NyhMD9
    Thanks guys as always!
    Will
    Leave a comment:
  • willcaddy
    replied
    UPDATE: Gearboxes and motors done :-)
    Hello everyone,
    Been a little while since the last update because money hasn't been kind to me lately! But I have managed to lock the motor gearboxes off so they are turning as one now. Once I have the money I will be picking up a pair of botbitz 85a brushed esc's from ranglebox. In the mean time I am going to have a go at some cad designs and maybe a cardboard or wood prototype so I can gage the size's of things. Let me know if you have any suggestions!
    Here is the video I made for it: https://youtu.be/-oQ7Z5hIcBI
    Thanks xD
    Leave a comment:
  • Theo
    replied
    I would add two small spikes or protrusions on each side so that you can ram opponents while the axe won't be obstructed by them driving right up to it. I mean spikes as in the spikes on tornado's scoop, something that size.
    Leave a comment:
